- 8 Jan 2003
- Scotland
Do the AMD drivers support dual 10/8-bit RGB output via HDMI 2.1?
I've just setup two Dell S2725QS monitors. I have both of them connected via the supplied (ultra-high speed certified) HDMI cables to my Sapphire Pulse 7900XT. I'm only able to set one of them to 10-bit or 8-bit RGB. The other is locked to 8-bit YCbCr420.
I've tried swapping the ports used on the monitor, swapping the connections around on the GPU but I'm always limited to one monitor being YCbCr420. The cables appear to be fine, if I plug one in at a time, they will use RGB.
