** TRYX FLOVA F50 CASE **
rjk
rjk
OcUK Staff
8 Aug 2007
Hi Gang
We are finally able to announce immediate availability of the brand new FLOVA F50 case from TRYX
The FLOVA is a Mid Tower case that features a contemporary look without resorting to festooning itself with wooden panels. :o
The FLOVA stands out from the crowd by achieving a smart aesthetic using a premium fabric mesh at the front and lower side panel area that is easy to remove for cleaning and maintenance.
This is a flexible chassis that has ATX / Micro-ATX / Mini-ITX and Back Connect Motherboard Support as well as being able to accommodate the largest and most powerful GPUs available today (420mm Max)
The Unique selling point of the FLOVA F50 is the TCF (TRYX Cross-Flow) fan that allows for an low profile and quiet intake area at the front of the case. The TCF Crossflow fan is designed to deliver air directly to heat sources throughout the main chamber of the case whilst remaining quiet. The fan has an internal control switch that allows you to select an appropriate fan speed
FLOVA F50 is available in Black, White and Pink and is shipping right now :cool:
The last fabric case I has was the Phanteks Evolv Shift Air. Really liked it, but so did my cat.
The fabric worked really well as a dust filter and responded well to a vacuum for cleaning. I'd be interested to see how this one does.
ah, I thought you wanted a green one like how Hyte have done recently on their cases!
MicroATX wasnt mentioned in our last few product roadmaps, but I do have TRYX coming to visit me in the coming week so I will pass on the feedback
If they do consider an MATX version I would hope that the rotary fan can be mounted up top as an exhaust or at the front as an intake. Maybe they could sell the fan separately to add an additional one into the case. Would make a good replacement for my Deepcool CH370.
