CCleaner
13 Sep 2024
Manchester
I use the free version of CCleaner just to remove old internet files and stuff. But when use CCleaner just to scan my drivers and chipset it always shows that they are out of date. My CPU and GPU are both Amd so I always go onto the the Amd website to update my drivers and chipset by using the automatic option.
So any ideas why CCleaner shows that they are out of date?
I think that Revo Uninstaller would do the same job for you and I believe it's much better regarded and generally serves more purpose. From what i'd read CCleaner has been frowned upon for ages since they became more advertising and bundled software heavy. (the cleaning, not the driver checks iirc)
I use an older version of CCleaner, that doesn't have all the adverts, just used for deleting cookies/browser history
Not used it in overnight 10 years. Used to use it every day before, especially in slow HDD days.
Don't see the point now and also they had a security blunder some years ago. Stay away i say.
Used to find it very good. Haven't use it in a long time. I used to only it use for cleaning up temp files and secure erasure.
Theses days I'll do it in the browser or reinstall windows. But I don't do either as often as I used it. It all just mostly works these days.
It went downhill sometime ago after piriform got bought out/taken over. I stopped using it back then & I started using the file cleaner built into W10 & now W11. I wouldn't touch it with a barge pole now its part of the firm that produces Norton.
I haven't used CCleaner for nearly 10 years, it went downhill.
Nowadays I use disk cleanup built into Windows and System Ninja.
CCleaner allows me to clean internet browser cache, but keep cookies/site settings, system restore point, temp files etc, it seems better than Windows cleanup. Also allows me to disable services and startup apps
System Ninja will do that for you without all the rubbish CCleaner tries to do.
Only reason I use Disk Cleanup is to remove old Windows Update files on computers will small SSDs.
