Evo is slightly small size.I don't know what the difference is between the Prime and the Prime Evo.
I've seen weird things with freesync/gsync and other advanced stuff, but not a monitor that's like... regular 60 Hz.Is there any logical reason the monitor would be causing this issue?
Seems really bizarre?
Just seems odd that's it's only just started doing it for some reason, nothings changed over the last 6/7 years!I've seen weird things with freesync/gsync and other advanced stuff, but not a monitor that's like... regular 60 Hz.
Every so often I have a similar issue with my daily driver.Just seems odd that's it's only just started doing it for some reason, nothings changed over the last 6/7 years!
Tried another monitor cable or changing from HDMI to DP or DP to HDMI?Just seems odd that's it's only just started doing it for some reason, nothings changed over the last 6/7 years!
I'll try another dp cable to rule it outTried another monitor cable or changing from HDMI to DP or DP to HDMI?
What are the odds that the replacement cable I ordered doesn't work!Tried another monitor cable or changing from HDMI to DP or DP to HDMI?
It's my last resort.I'd try a full Windows reinstall before throwing any money at it. Copy anything you need to save to a separate drive, build a USB installer, and delete all partitions on your OS drive.
Go with a minimal install for a few weeks (drivers and only the software you need), see if you still get the problem.
New cable same issue. Least we've ruled out the basic one!Tried another monitor cable or changing from HDMI to DP or DP to HDMI?
