- 17 Mar 2025
- solent sound
to me this is all sounding more like the psu especially if it works fine on the igpu [much less power needed here than either of the two gpus that you have]
depending where you are , finding someone else with either a psu to try it with or a machine you can just try the card in [with a known to be working fine psu...
thus this would help rule out that line of enquiry, or not rule it out obviously depending on the outcome of trying the gpu with another psu/machine
im not saying it is [or isnt for that matter] the psu but it should really be the next thing to try and rule out at least.
