You wash your screws?
Posh git![]()
Another fan of all seasons here (in fact getting some new ones fitted today!), the loss in range is negligible, and the poor traction of the Niro in the wet makes it a bit of a no-brainer
You don’t need EV specific tyres, just make sure you have the correct load rating. EV tyres have a higher load rating typically and tend to be lower rolling resistance for improved economy. But that of course means less grip, which is ironically why a lot of people who drive an EV spiritedly declare “you can feel the weight”.
Back in January I put non EV specific Michelin CrossClimate 2 all weather tyres (load rating 95) on my Cupra Born and noticed about 10% drop in efficiency. They are about 5% since they wore in a bit. But the grip in the wetter winter months was much improved. My older but still legal Goodyear “EV” tyres were useless in snow and were giving wheel spin in cold wet conditions.
All things considered I felt the compromised grip to add ~10 - 15 miles of range was a terrible trade off.
I used to have space not at the moment.
We had a few years of really bad winters and cross climates were decent. I think they come into their own in colder temps when summer tyres feel lackluster. They'll keep you going in light snow.
Last few winters have been milder and most of driving is in the city. So I went back to summer tyres with better wet performance.
)That's why I went with Continental All Season instead of the Cross Climates - all the reviews/comparisons I found say that although the snow performance isn't as good as the CCs, the wet performance is better.
I take it most of you guys also don't have the space for running two sets of tyres and swapping them over for winter?
Yeah a cheap/dirty one definitely isn't any good!This is an EQE mate - I have standards to uphold!
(Also they're £30+/corner cheaper which may have influenced the decision slightly)
Unless they are cavernous you can open the frunk from the outside, they aren't very useful.Just adding fuel to the fire but I use my frunk all the time.
Due to all this chatter regarding a 'frunk' I decided to check the iX1 and it has what can only describe as a full bay, looks the same as an engine (similar to M135) with all the covers etc. in there as I was thinking it would be a good place to store the cable, colour me disappointed
I just keep my charging cable in there.
Don't even bother keeping the Granny charger in the car, never used it in 5 years of EV ownership.
