- 19 May 2010
- Cheltenham
On a long run 250Wh per mile is relativity easily achieved with 20" wheels, and in temps above 10c, so 360 miles on 100% charge, bottom buffer isn't huge but power loss isn't that bad at close to 0% and the charging speed is still good if you need to rapid charge averages 150kW from 3-60% and tapers off hitting 100kW at 73%, about 25 mins to do 5% to 75%, with the obvious fact that 5% is 18 miles gives you a bit more wiggle room for chargers failing etc.
Distance to Prestwick is about 350 miles, plus a 20 mile ish detour for my mum to make me a cup of tea, so I’ll need to do a charge at some point toward the end of my @Journey
Given it only has just under 5000 miles on it currently I was considering the train or flying to save the mileage but it should make for a nice round trip and a good test if I do it!
