That’s for sure.
I’ve only done the first mission and a bit of training so hopefully it’ll get better further in.
Shillup said the first few hours are shiite but then it vastly improves
That’s for sure.
Modded MFG works btw too, x6 available on RTX 40 series. ON my 4090 using anything above 4x at 4K output results in a lower baseline fps, around 40fps base at 6x MFG - This is less efficient than DLSS MFG obviously as the mod uses FSR 4.1's MFG system, but 4x works more than fine with only a slight panning motion judder to game world highlights if you are sensitive to such things.
Dynamic is available too. No other obvious artefacting in the limited testing I did before dropping back to DLSS FG 2x which is perfect and gets over 200fps if fps is uncapped on a 4090.
For me in this game, 100fps cap + Ultra everything + 4K DLSS Balanced with 2x FG = Quiet running 4090 so can game peacefully
Which leaves lots of headroom for path tracing using DLSS Performance.
Time to get yourself the master race gpu family!![]()
AMDs frame gen still has a long way to go.
Such a great tech MFG though, usually x3 is plenty with dlss balanced/performance to get locked to 225 on a 240hz monitor so had no real need to go to x5 and above. x4 is very good for the path tracing games though like RE and pragmata and I suspect this game when it gets PT.
There are dozens of us! Dozens I say!Wait, are you suggesting that there’s people who don’t own a 50** GPU?
Are we now a 3rd world country or something.
smh.
I have a 5090. and a 3090 sitting and being used as a door stopper at the momentWait, are you suggesting that there’s people who don’t own a 50** GPU?
smh.
4090 is running its full 5byear warranty I tell you.
Poor thing, stuck on having to go out of his way to use an inferior version.
I always knew he would like and want the tech. But he wasn't having it. As I have always said, stubborn![]()
Timmy be loving it now he has a high hz monitor and finally sees the true benefit of MFG/high fps. WHAT A TIME TO BE ALIVE!Even HUB are now starting to come round and praise MFGTimmy be loving it now he has a high hz monitor and finally sees the true benefit of MFG/high fps. WHAT A TIME TO BE ALIVE!
I’m liking the look of this game but have a choice - PC or PS5. What’s the group view?
For context I play games like Ghost of Tsushima / Yotei on PS5 and Assassins Creed on PC.
I don't know why people don't connect their PCs to their TVs more often
Been doing it for well over a decade.
