RTX 4070 Troubleshooting help
17 Oct 2025
UK
Hi,
Looking for advice on an RTX 4070 showing artifacting mainly in Apex Legends.
Symptoms:
  • []RGB/checkerboard artifacts
    []Mostly in skyboxes/light sources/rocks
    []Gets worse the longer the card is under load
    []Desktop, videos, and browsing are fine
    []Used to happen across the whole game, but now with the things above now mostly limited to sky/light rendering after troubleshooting
    []No crashes or BSODs
What I’ve tried:
  • []Reinstalled Apex
    []Deleted Apex shader cache (psoCache.pso)
    []Cleared DirectX shader cache
    []Used DDU in Safe Mode
    []Installed latest NVIDIA driver clean
    []Reset NVIDIA settings
    []Lowered texture streaming budget to None
    []Lowered graphics settings (turned of GPU Accelerated)
    []Disabled some rendering features
    []Tried different fan curves
  • Tested VRAM underclock (-502 MHz in MSI Afterburner)
Results:
  • []Clearing shader cache and lowering texture budget helped a lot
    []VRAM underclock cut artifacting roughly in half
    []Stronger fan curve didn’t help
    []EA FC 26 was mostly fine aside from one quick artifact in a menu however did produce the highest Temperature Hot Sport and Average temperature
Temps:
    • []GPU (Idle - Desktop): 45–50°C
      []GPU (In Game): 72–80°C
      []VRAM junction: 68–74°C
    • Hotspot was around 92°C before, now hitting 105.7°C max
    Trying to work out if this sounds more like:
    • []hotspot/contact pressure issue
      []unstable VRAM
      []Apex/driver issue
      []or early hardware failure
    I’m not fully convinced the GPU is dying since:
    • []normal desktop/video use is perfect
      []fan curves, settings, and memory clocks clearly affect it
    • other games seem mostly stable
    Any opinions from people familiar with RTX 4070 hotspot issues or Apex artifacting would be appreciated.
    I’ve tried troubleshooting using AI but I can’t fully rely on it so I thought I’d ask here. My PC was bought about 3 years ago but I can’t remember where.
If you don't have any problems in other demanding games, then it sounds specific to the game (e.g. a driver issue), however, you also said:
Which is a bad sign there's a hardware fault!
That's a better sign.
Do you have anything showing in the event viewer?
This isn't a 13th-14th gen CPU, is it?
Which model is your 4070? If the contact pressure is an issue, e.g. one VRAM chip not cooled properly, then it is likely other users have had the same problem.
The hotspot temperature sounds high to me, though you said a higher fan curve didn't help? What about underclocking the GPU?
The cooler needing attention could cause what you're seeing and if so, best not to use the card too much until you get it checked out.
  • Like
Reactions: G J
You said you've set a higher fan curve, are all the fans working/spinning?
It's early hours in the morning and the temperature has dropped abit from the last few days, I've taken the under volt off and I just done a 3min FurMark 2.7.0.0 stress test.
Card is a ASUS PRIME RTX 4070 OC
I'm leaning towards your GPU may need repasting/thermal pads changed. Any warranty left on the card?
It’s an Inno3D or something along those lines
There are reddit threads of people commenting on having to repaste their Inno3D cards.
One poster even mentions the screws weren't tightened evenly, which was contributing to poor contact.
Even if it's an old bank account it sounds like it's within the 7 years that HMRC might want to trawl back through your accounts should they wish, so I'd imagine the bank would need to keep them just in case. Calling them up, saying you used to have an account but it's closed and can you have a copy of your accounts from whatever the time frame was might work. Or they might be able to just look at the statements and tell you the info over the phone. I've not tried this so it might just be a shot in the dark.
Just noticed @hornetstinger has said the same.
