Between Saturday and yesterday evening mine was on charge once for 10 minutes and it still had over 30% battery on it before I charged it to full.I'd be interested to know how you get on with battery life. I charge my ultra once a day while in the shower (up to 80%) then 24 hours later it still has loads off juice before charging again.
The 12 does boast 24 hours but I don't want to be cutting it too fine (especially if the battery degrades after a couple of years).
Yeah will keep you posted.I'd be interested to know how you get on with battery life. I charge my ultra once a day while in the shower (up to 80%) then 24 hours later it still has loads off juice before charging again.
No problem he’s my go to for anything fitness related tech wise.This is really great, thanks for sharing this.
HR still not accurate enough for running based on that but it will probably be much better than the original for just general daily use.
Think I’m going to go for the upgrade but will continue to use my Polar H10 strap for running.
Not running, however when cycling mine tracks my heart strap whenever I check it. There is a slight lag, like shown on the YouTube video I linked to earlier.Went for my first run with the Ultra 4 yesterday and not impressed. I did an easy 20 minute run at a pace where my HR never goes above 135bpm which I know from years of experience and using the Polar strap. It started off fine then started climbing aggressively towards 155bpm where it stayed for a while, then suddenly spiked to 168bpm. This isn't being slightly off, it's complete nonsense. I tried to adjust the band which made no difference but when I switched it to my other wrist (the one it's not configured for) the readings admittedly improved but still not entirely accurate. I finished the run with 5 x 100m sprints / 120s recovery jog, on a Polar strap you can easily see the spikes in HR and it quickly drop down during the recovery jog, with the Ultra 4 it just doesn't seem to respond quickly enough and you just get a high-ish reading for the entire time.
So either there is something wrong my wrist that the optical technology doesn't like or the Ultra 4 optical HR sensor still sucks.
Have a race this morning in central London so will be using my Polar H10 again![]()
Ah ok, probably not worth the change then. I get 2 full days almost out of the series 3, I’ll take it off charge in the morning and then charge it again the following evening which suits me just fine.Doubtful but the battery life is definitely noticeable
Try Deleting them from bluetooth, remove from your apple account, hard reset them and repair them to the phone, thats what I had to do.Does anyone use AirPods with the watch away from your iPhone?
I have been using my watch and AirPods for months when going for a run but ever since I got my iPhone 18 I can’t get my AirPods to work with my watch on its own.
