9070xt freezing windows
9 Aug 2013
S. Wales
ive a major issue with my card, all was fine yesterday,came to use this morning and getting constant freezes when just on desktop, maybe 5mins after windows signin, switch to igp and all fine, even clean install windows still freezing but igp on my 13500 is fine dont get it as nothing changed since logging off yesterday afternoon and turning on this morning. gaming is instant freeze.
so confused
Have you checked event viewer to see if anything is being flagged in there at all?
I assume the 9070XT Drivers are fully up to date?
I has this quite frequently about a week after upgrading to a 9070xt with new Antec platinum 850w psu. So much info said possible PSU or a driver issue.
I updated everything, made sure fast start was disabled and still got it, usually when the system was idle or a game was paused.
I put Adrenaline back to default instead of using an undercoat too.
This stopped it happening on everything except Metro 3033 redux but disabling Steam overlay fixed that. Got to try undervolting again and see if it starts up but Metro Last Light Redux has gone wrong so far.
I think I've sorted it. It's either dodgy HDMI cable or the connector as on display port it's fine, all hel breaking loose on HDMI. I'm just reinstalling windows for 5th time lol. But this time on dp and not skipped a beat ATM n im pretty much fully installed
i thought i sorted but i just cant figure this out, ive literally tried everything, on the 9070xt it will 100% freeze in windows using in few mins, stress test it instantly freezes, gone through mulitple fixes, my igp 13500 works fine, i even have the amd drivers in and gpu is showing in device driver and adrenaline, no heat issues, at wits end been through the cmd repair options. kust really strange that this came out of blue, doubt much u can tell, ive reseated everything even using just one stick on ram, is it gpu? brought from oc at launch, wits end been at it 3 days, though scotch is going down a treat for me stress:cry:
actually just froze on my igp, its carnage, installed windows like 4 times lol
Is the bios up to date and chipset and motherboard drivers up to date. Do you have any over clocks remove all of them.
Everything all as expected all drivers latest as with bios I've even stopped windows driver updates as can cause issues. All dsim services run literally scratching head. It's just weird as freezes with no load at all on gpu, which I thought would think was software related. The igp is 99% ok as froze only once. I've stress tested components and all good except obviously gpu but that freezes with no load, possibly buy cheap mb to see if could be issue.I see if can find someone local who can test the gpu. As think only option left,
Hey, I wonder if this is more CPU than GPU ? Just as you mention it froze once when using the igpu and not the 9070XT.
Do you have another system to test the GPU in?
Could you try another PCIE slot (if your board has 1)?
Are you using a riser cable at all or is it connected directly to the PCIE slot?
Guess possible Repasting and reseating cpu is on menu this morning as going to try run with literally bare minimum of everything connected. To rule out anything else interfering. Which extremely unlikely but just to rule out, do want to upgrade but price if ddr5 ruling that out.
I got day off so full day of troubleshooting. :)
I don't but will put call out later if can't solve today using primary pcie won't find in the other I am looking at b grade cheap mobo to rule that out.
What PSU do you have?
I was having all sorts of issues with my 9070XT.
I tried so many things to fix including a Win re-install. Full machine strip down and rebuild. Re pasted the CPU. Swapped out cabling.
And that’s just off the top of my head...
I assumed it could not be the 850W Platinum Corsair PSU as it had more than enough power for my setup.
The most confusing thing is I could leave it bench for extended periods using 3DMark which made me think it could not be the PSU right.
Then when reading through the various forums, reddit and whatever else I clocked someone having the same issue, and it was the PSU...
Literally as I was reading it, it made so much sense for my situation
Essentially games, given they can be all over the place with demands on hardware, scenarios can change very quickly. This was making the power demands spike. And the well powered, decent branded but older PSU I had basically said nah mate, and the system would crash out.
Might not be your situation but in case it helps.
I don't think you have mentioned what PSU you have. If it's an older one maybe "borrow" a newer one off a mate or something and give it a whirl.
Of course could not be related lol! But this is what happened to me and if it helps etc :)
I have a 750w cordair sf750 . Since launch haven't really had any issues really. But this one has come out of blue, just turn on PC and started to freeze, tbf I thought osu as in the border but it's platinum so thought would be ok, but last few days been looking a cordair tsf100 or the rog 1000w, but thought as there's no load I sort of ruled that out, maybe it could be
How old is it.
Yeh worth looking at...
With the PSU's, not so easy just to pop in a spare and test right.
I was going to dispose of the 850W Corsair Platinum I had but really there is nothing wrong with it. It went into an older build I have to swap out a Bronze PSU.
Oddly.. I was so twitchy about playing anything as didn't want to damage anything right. But even before I put the new PSU in I knew it would be that, was just so sure of it based on what was happening to me etc.
And not had any issues since (not a single crash)!
PSU in case interested is
MSI - MPG A850GS PCIE5 Modular ATX PSU - 850 W
Looking through this thread again. Does it freeze from cold longer than a warm restart. I’m wondering if this is temperature related.
PSU I Bought it of matt100 in March iirc.
It freezes 100% of time on desktop so always from cold but using igp at times but the gpu in background at a few watts.
Been out to find thermal paste, I have more luck finding a winning lottery ticket. Can't find anywhere so had to order off Amazon for tonight delivery. Also certified 2.1 in case
It could be a PCIE conflict.
I had a single freeze in Firefox, bizarre problems with display detection and unbearably slow display mode changes.
Moving the SSD and soundcard to the chipset lanes fixed it.
