Thanks Mike.
Is it possible/likely that by moving the radiator effectively a further 25mm into the case that it could foul the pump arrangement on the CPU.
I assume not since it would appear you would normally have to mount a fan on the radiator anyway.
By leaving the existing case fan in-situ and intact you could if need be simply pull air through the radiator.
