***The Official Q6600 Overclocking Thread ***
Did you apply the thermal paste as per instructions for quad cores?
(Line across the words)
A resit might drop temps a bit but they are nothing to really worry about. That is 4 cores at 3.6ghz, massive amount of power. :D
Yep 3.6, I've disabled speed step but I can see my Core Speed and Multi fluctuating in CPU-z, what haven't I disabled properly ;)
Yeah not too worried about the temps TBH.
is it possible to clock a Q6600 to 3GHz on Stock Cooler? Ive scanned through the thread but couldnt find a direct answer.
Probably, the Q6600 G0 is basically the same processor as the QX6850 which will come with a bog standard cooler.
Try it and then look at your temps. If they are to high then swap the cooler for a better one. I think you should be able to do it though. The thermal tolerance for a Q600 G0 at stock speeds is 71C but if you crank it up to the QX6850 speeds then you need to look at the thermal spec for the 6850 which is 64.5C
Cheers
yeah when i finally order my pc im going to go for the G0 and ill try to OC it to 3ghz.
Although ive never oc'd in my life, where would be a good place to read up on it. Ive read the stickies and have a rough idea. Im planning to get the DS3 Gigabyte motherboard.
^^Getting it to 3GHz is no problem, it should be ok on the stock cooler, i swapped it straight away fro my old TT Big Typhoon. I'd advise you to buy a new HS&F, only another £25-40, gives you peace of mind and the ability to overclock abit more, maybe 3.2-3.4GHz.
Just swapped out a B3 for a G0 (17th August pack date). Seems to run cooler by about 4C, at 2.8Ghz now. Sure it will have a lot in it to OC, however gotta write my paper!
3.9...
I know this Q6600 (G0 stepping) can go higher but my RAM is holding me back :mad: it's already on the lowest ratio and running @ 850MHz, just wont go higher. I do have 8GB though, but i'd rather have more RAM than less RAM thats slightly faster.
Specs in sig.
Im thinking that i have got a bad clocking chip, needs 1.5v in bios to be stable at 3.4 :(. What is the maximum voltage i should be looking at?, bearing in mind that it only just hits 60C under water at this point.
When people quote voltages, are these in bios or cpuz? because at idle my vcore droops by 0.05v and anything up to 0.125v under load, is this normal?
Alex
I have disabled EIST (Ehanced Intel Speedstep Technology) in the BIOS but when I run CPU-z I can still see the muliplier and fsb changing when the machine is idle!
How do I disable Speedstep on the Abit IP35
EIST and C1E.
3.9...
Specs in sig.
Stable?
Alex
Hmmm my G0 does 3.8 on 1.5 and the temperature is only 42c idle on water. Your temp seems too high, what water cooling is it?
If it's already at 60c i wouldn't go higher any higher on the voltage.
Just got mine :D
Batch : L726A977
Pack Date - 16/08/07
Will prolly set it up tommorrow when my new heatsink should arrive!
It is about 42 idle and 60 load at 1.5v, using a Pa120.2 with swiftech apogee with quiet fans.
The system is still here and is in a closed case, so if you have a programme you want me to install and some benchmark I can have a look at giving it a run if I get time. :)
Your volts look very low :confused: 1.150 v, I thought default was 1.280v?
