Hi guys,
I was enjoying a quick game of Counter Strike (first time in approx. 1 year) before my computer decided to power down. Once powered down, my PC then tried to boot several times on-off-on-off before I switched the power off completely. After turning the power back on almost straight away, my PC continued to irratically boot on-off-on-off again. I proceeded to switch off the power once again and gave it a good couple of minutes before trying again, this time, the PC booted but no post and my monitor light went into standby.
I have tried the following:
- Removing GPU and running on onboard gfx. Resulted in no post but monitor detected an output (green light)
- Disconnecting all components apart from CPU, HDD, and 1 stick of RAM. Resulted in no post, no beep.
- As above with 2 sticks of RAM. Same result
- Reset CMOS with no result
- Checked PSU voltage on no load. 12, -12, 5 and 3V present
- Checked PSU voltage on load - Same result as above
After these tests I led myself to believe that my motherboard had failed. I have no replaced my motherboard but have the exact same issue. So my current state after switching my PC on is:
- No post
- No beep
- CPU fan spins, front case fan spins, GPU fan does NOT spin, back case fan does NOT spin
- HDDs feel like they are spinning
My current spec is as follows (sorry it's vague - I'm out of touch!):
i5
Gigabyte Z97 D3H Motherboard
8GB DDR3 Corsair Dominator (1333MHz)
OCZ 700W PSU
Samsung SSD
Any help will be greatly appreciated! All my PC experience is exhausted
Many thanks in advance!
- No post
- No beep
i5
OCZ 700W PSU
Samsung SSD
