Right, fully built and working. Looks awesome in my opinion. These pics might be a bit guff and probably dont do it justice, but here goes:
http://www.scottishgamers.co.uk/ll360/DSCF0050.jpg
Xbox stripped completely and ready to go in.
http://www.scottishgamers.co.uk/ll360/DSCF0051.jpg
Case prepped.
http://www.scottishgamers.co.uk/ll360/DSCF0052.jpg
Everything installed in the case.
http://www.scottishgamers.co.uk/ll360/DSCF0053.jpg
Closer view of the installed system. What you cant see here is the sound proofing foam on all the sides of the case around the drive bay area. There was also plenty of clearance between the motherboard and its tray for anyone (like myself) who have replaced the xclamps with better fittings.
http://www.scottishgamers.co.uk/ll360/DSCF0054.jpg
System fully built and ready to go. Camera flash made the top drive cover look silver, it really isnt
http://www.scottishgamers.co.uk/ll360/DSCF0055.jpg
Full system again, but this time with the typical peripherals you may have hooked up to it, plus the drive open. And yes Mark you do get to see the Ring of Light around the power button
http://www.scottishgamers.co.uk/ll360/DSCF0056.jpg
For anyone interested in the scale of it.
http://www.scottishgamers.co.uk/ll360/DSCF0057.jpg
Again, just for scale.
All in all I am pretty impressed with this case, and it takes a lot to impress me. Whether its worth shelling out 85 notes for is for you to decide. It looks lovely and should fit in nicely with most home theatre setups, and wont look totally out of place.
The build quality is impeccable and is well justified in the price. The poor cooling of the original systems is well handled too, with a 120mm fan already in, and it also has a fan splitter cable, allowing a 2nd 3 pin fan to be installed wherever you see fit.
Loving it already
Case prepped.
Loving it already
