0 to -5 degrees
25 Nov 2007
London
did a micro atx build today, with Amd 4800 socket AM2 + abit nf-m2sv mobo
tried coretemp + speedfan and both temps are between 0 and -5 degrees....
guess room might go as low as 15 degrees so that is BS.
any help to fix this temp madness?
thanks!
what does your BIOS say the temp is ?If your bios tells you the same,then update to the newest BIOs available.
I have a 4800+ AM2 aswell, the temperature readings are so crappy. im idling at 6 degrees in a 20 degree room, my bios reports the correct temperature though, just nothing in windows can pick it up, im on an evga 590 sli. Mine jumps to over 120 degrees sometimes, which is obviously wrong, does yours do that?
Check the manufacturers website for bios updates, also read the forums on there to see if anyone has been having simalar problems ;)
bios said 25 degrees but im not going to go into bios all the time~!!!...
and no i havent seen it go higher than 2-3,,,
so just add 20 -25 degree's?
