01 mondeo fuse layout
23 Jan 2006
afternoon chaps.
well got the new car. suprise I have alreayd broken it (well got it brokwn at least)
6006E 6 cd head unit wont take CD's. error code 3. phoned ford. suggested holding down eject and load at the same time. or removing the fuse to reset the head unit. well the handbook doesnt have a fuse layout for the central fuseboard.
does anyone have any idea where I can find such a layout please? had a little google search to no avail yet.
thanks in advance.
Does it not have ot on the fusebox cover? Failing that, a Haynes will have one. Someone in here must have it, or take a trip down to the reference library.
it is on the side of the glovebox! thanks.
edit:
But i pulled the fuse thats meant to be for the stereo...but it didnt reset the stereo. so I am totally confussed now.
only just got the thing dont want to go disconnecting the battery etc to attempt to resurrect a broken head unit. will phone the dealer tomorrow to discuss the 200 + Vat it will cost for ford to fix I think.
