011 mini on it's side and silent for HTPC, is it possible???
8 Jul 2021
United Kingdom
Hi All
I'm looking to finally ditch my 9yr old iGPU based HTPC and looking to build another but with at least a 3060 if the prices ever come down
I was looking to stay with streacom as i love my FC5 and their style is classy and fits so well with the rest of my AV setup but my plan of using the F12C wont work as it's no longer being made and although there is hope of a new revision next year it's only in the planning phase according to streacom.
As an alternate i was thinking of getting an 011 mini and turning it on it's side but i have a couple of questions
  • Are the feet removable without damging the base?
  • What would be the best way to keep it cool but as silent as possible for example with an AMD 3600/x with a 3060 maybe Ti but nothing above that, it's unlikely i'll ever do any gaming on it, on it's side there would be 30mm clearance either side and 60mm above with about 100mm at the back.
I seen a few youtubers say noctua is the best but would stepping up to watercooling improve things?
Also open to any suggestions on an alternative, i have looked at the silverstone HTPC case and wasn't a fan and considered some ITX systems like the SSUPD and FormD T1 etc but they would offer no 3.5" bays and again i would be concerned about the noise, also looked at other midi towers but most are too tall to fit in my TV bench or too plastic looking.
Likewise if anyone from OCUK notices a forgotten F12c collecting dust in the warehouse i would be happy to take it off your hands
I can consolidate down to 2 x 3.5" if need be or even put them in a USB enclosure and hide them but my main aim is to keep the HTPC AV unit look and my thinking is i'm not going to get a quiet system with a slim case which is also why i ruled out the fractal 202 or other ITX cases, i forgot to mention that i would be putting a brushed aluminium panel on the front of the 011 mini as opposed to glass and RGB isn't my thing.
I did like the Fractal 605 but like the F12c it's not available anymore, it seems the whole HTPC must be a thing of the past with all the streaming tech available.
