Got a problem, a mate gave me a 02 Arrow wireless headset yesterday and i cant get it to pair with my D600. Its got no instructions so can anyone give me any ideas
You must first of all get the headset into "pairing mode" mate, this is usually done by holding down a button on the headset for like 5 seconds. Then a light on the headset should be lit up solid blue to let you know to pair it up, then search for devices on your D600 and it should pick up the headset and away you go. You may need to give the headset a "PIN", just create your own or it could be the default one which you would need to find out or try and look for an online manual somewhere.
Have you tried holding them both down? I thought there was only 2 buttons on a Jabra JX10 Headset until I saw one on the back about the samw size of the end of a pencil!
