- 4 Dec 2008
One of our PCs here is exhibiting some strange behaviour, freezing on shutdown, restarting on shutdown, getting IRQL_NOT_LESS_OR_EQUAL on shutdown etc.
Memtest comes back completely clean. Sfc /scannow found some violations and it freezes on shutdown less now, but still does it. Changing the IRQ of the WiFi card to 7 also helped a bit.
On driver verifier, it gets 0x0000035. Have tried the regedit M$ suggest but still no luck. Any ideas? Am about to analyse a full memory dump of it so shall update when done.
E2140 2.4GHZ 1.1v (does it at stock too)
PNY 2x1Gb PC6400 1:2.66 (stock speeds)
Gigabyte GA-G41M-ES2L
WD1600AAJS
HP DVD400i
Antec Basiq 350W
Netgear WG311v3
Am certain it isn't a hardware problem. It works fine other than shutdown issues as well as this.
Cheers
EDIT:
Tricky. I'll try get another one.
WD1600AAJS
HP DVD400i
Antec Basiq 350W
Netgear WG311v3
Cheers
EDIT:
Code:
* Bugcheck Analysis *
NO_MORE_IRP_STACK_LOCATIONS (35)
A higher level driver has attempted to call a lower level driver through
the IoCallDriver() interface, but there are no more stack locations in the
packet, hence, the lower level driver would not be able to access its
parameters, as there are no parameters for it. This is a disasterous
situation, since the higher level driver "thinks" it has filled in the
parameters for the lower level driver (something it MUST do before it calls
it), but since there is no stack location for the latter driver, the former
has written off of the end of the packet. This means that some other memory
has probably been trashed at this point.
Arguments:
Arg1: 8a9fce48, Address of the IRP
Arg2: 00000000
Arg3: 00000000
Arg4: 00000000
Debugging Details:
***** Debugger could not find nt in module list, module list might be corrupt, error 0x80070057.
GetContextState failed, 0x80004002
Unable to read selector for PCR for processor 0
Unable to get current machine context, HRESULT 0x80004002
Unable to read selector for PCR for processor 1
DEFAULT_BUCKET_ID: DRIVER_FAULT
BUGCHECK_STR: 0x35
STACK_TEXT:
STACK_COMMAND: kb
SYMBOL_NAME: ANALYSIS_INCONCLUSIVE
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: Unknown_Module
IMAGE_NAME: Unknown_Image
DEBUG_FLR_IMAGE_TIMESTAMP: 0
BUCKET_ID: CORRUPT_MODULELIST
Followup: MachineOwner
