- 27 Jul 2005
- The Orion Spur
Panel : Dell 2407 rev ao4 (connected via DVI)
Driver version : 163.71
GPU : 8800gtx
OS : XP
Hello guys, since owning my Dell 2407wfp rev a04 I've never been able to use the 1:1 pixel mapping option on my panel when windows is loaded, before windows loads I can access and change the 'Wide Mode' option to 1:1 but as soon as the desktop appears the option is greyed out and it reverts back 'Fill', I go into the nvidia control panel and the scaling option is setup as so,
has anyone else got this problem also ?, can you guys access your 'Wide Mode' option (in display settings in your panel menu) once windows has loaded ?.
GPU : 8800gtx
OS : XP
