Caporegime
Hardwood lipping to all 4 edged and with the veneer no mdf is exposed. If the mdf has a chance to get wet in your apartment you have bigger problems than a few doors.
I wonder if part of the issue is that with most commodities, the top end luxury items (of which a £3k door is to most people certainly one) typically sacrifice some practicality for charm, character, and panache.
To many, there's no panache or charm to be found in anything made of MDF, no matter how well constructed and long-lasting.
Even if it were true that solid wood doors have less longevity than MDF veneer, do these wealthy people really care that their doors will last 20 years instead of 40 before they need to be maintained? Do they care that the doors might need sanding or re-aligning in five years?
The owner of a Patek watch doesn't worry about getting it serviced for £1k in 7 years and get a Casio digital instead, they just enjoy the luxury and charm of it. I'm not sure why doors are any different to rich people.
However, you've explained your points very well, for what it's worth. Maybe this:
You'll find that mdf and other composite reconstituted timbers are what most timber products are made of.
...is the key point that most of us plebs are missing!
