1.3, 2.0, 2.2 PSUs?
28 Sep 2007
Merseyside, UK
Hi all, so this is my crap old PSU, and it says its an ATX 1.3 PSU.
And this is my mobo.
So my question is this, if I buy a new ATX 2.0 or 2.2 PSU, will it work with my motherboard, or do I have to stick to ATX 1.3 PSUs?
I'm bloody confused.
Fully compatible (& most ATX 2.x PSU are backwards compatible anyway). Your mobo has 24-pin EATX power connector, a ATX 2.x feature so suprised PSU is ATX 1.3 unless a 20>24-pin adapter in place :confused:
Recommend either Enermax, Corsair, Seasonic (also make the latter), Tagan, PC Power & Cooling, OCZ ;)
Just had a look on my mobo, it is an EATX power port, but the cable going into it says 20+4P on the side. Doesn't look like any adapter is in place.
Alright, thanks for the help.
Can anyone recommend a decent budget PSU? 400W should do it, and ideally enough power on the 12v rail to power my 8600GT.
