When somebody actually makes working DP 1.3 chipset ready for mass production. Will this ever happen is the question. At current rate, Thunderbolt may achieve more uptake before DP 1.3 ever gets released.Does anyone know when display port 1.3 monitors are expected to be released?
Maybe they just jump straight to display port 1.4 (or 1.4a) next..Does anyone know when display port 1.3 monitors are expected to be released?
Quite a lesson for standard makers to produce a standard which is actually feasible to implement, unlike "here is a new standard for you - we've doubled clock speed, now make it work!" /sJust to put into perspective how sorry of a situation this is; by the time the first DP 1.3 monitors hit the ground the specification/standard will have been out for over THREE YEARS!
This works well for static images only - its hard to synchronize two separate displays to scan at exactly same time (otherwise you will see "tear" in the middle on anything quickly moving). DP has some provisions for stream aggregation but its flakey (since no one is actually using it much) and would be nightmare from customer support standpoint (since most likely will cause common compatibility issues with multitude of possible hardware combinations).Could the manufacturers do what they did with the first 4K monitors and take a DP signal and split it across two electrically separate 1920x2160 displays?
Also first-gen 4K displays were a bit different, since they still used single DP cable. Going above 1.2 will require aggregating two separate cables (like 5K Dell monitor does), which is quite more prone to problems above.
You mean the cable which nobody was able to make yet?I'm not sure that's correct. A DP 1.3/1.4 cable is capable of two 2K streams at 120 Hz
It does work sometimes, sometimes it does not. First gen 4K displays also worked ok for a lot of people, but many had problems with them.And speaking of 5K, I remember reading - probably on Hardforum - about someone trying one of the 5K monitors with quad Titans and not getting tearing.
TBH 4K does not really need high refresh DP 1.3 - since I doubt significant amount of people will be actually able to drive UHD @ 120Hz - it will require quite insane hardware even for the near future.
