1.5k Spec Check
2 Aug 2009
UK
New PC for a friend, mostly for MMO gaming
Thought I'd check with you guys as I'm about 2 years out of the loop
He'd rather stick with AMD if possible
Thanks
Thanks Stulid, looks good.
Yeah he'd rather it be smaller, he's been pretty set on that Corsair case since I shown him it.
He can go over 1.5k, he said money isn't an issue.
You can go with the Corsair case, only problem is I don't think the 290x will fit.
This 970 on the other hand will fit no problem. I know you said he prefers AMD but you can't go wrong with this card :)
Okay update:
I spoke to him last night and he said he is willing to go up to 2-3k
He is also willing to go with Nvidia if it means better performance (So possibly Titan X?)
I'll ask him what he thinks of that case
Was just about to post the exact same spec to ask what you thought haha.
He said he isn't a fan of the case, will the titan X fit in the corsair case I linked before?
Also I've tried to convince him to build it himself but he just isn't comfortable, I'd do it myself but he's in Scotland right now. Will OcUK do the build for him if he asks?
Thanks
Yes the TitanX will fit, it has no oddities to its design, nothing sticking out or is too wide.
Thanks
Yes they will, but it might be from £60 or more, depends on how complex it is and the man hours put into it.
I know -.- he's just inherited quite a bit so he's going kinda ape.
I've just emailed OcUK regarding the custom order so he should be ordering tomorrow.
Will post pics when it arrives :)
£1500 would get a great machine for MMO. Crikey.... no point wasting his cash.
He could save it and buy again next year if he wanted!
Going to be looking myself soon after 4 years of spending £1600 but its still good now.
