Is it generally reccomended to run ddr3 tri channel ram kits at 1.66v, as most are rated for 1.65v, which cant be selected in bios, i currently run 6gb of ocz reaper c7, runs at 1547mhz, 7-7-7-24, 1.64v. Every now and again i get a cold boot on turning on, if i hit reset the system loads fine. Rig is an i7 920 DO clocked at 4ghz, 21 x 193 bclk, thinking this may be a ram issue. System has been tested stable with p95, ibt and LinX, qpi voltage at 1.312500, vcore of 1.2750. Mobo is an asus p6t dlx v2.
