1 card, 2 screens
5 Dec 2003
London taaan
What's the best card (only want one) to run two 19" TFTs?
Not going to be used for gaming (at all).
Suggestions? Recommendation?
If your planning on using DVI get a card with Dual DVI as if you use one monitor on DVI and the other on VGA you will notice more colour difference than using both on DVI. If your lucky and get two panels from the same batch you wont notice the difference when using same input!
