They will have their own unique internal IP, e.g. 192.168.0.10 & 192.168.0.11 but you can't have two public IPs.
What are you trying to achieve with two?
they are both wireless connections but i can use ehternet if i want to. the bt homer hub assigns the same ip as they are both connecting via the hub, i was wondering if its possible to change the ip of either computer?
well me n my friend can't play on the same poker table online coz wee have the same ip as we shre the sameinternet connection. and we want to play against each other but we can't. is it not possible to chaneg the ip of eithe rof the comps to make them different ? cheers duke for the info.
CS:S being Counterstrike:Source?
If so, it didn't. We used to have "lanners" on our server all the time.
DynDNS won't change your IP though, or your reverse DNS.
Er, what are you on about? The OP asks for help with a specific problem, you offer something totally irrelevant with "There may be a solution." then blather about looking "at all scenarios"?
I mean, if we're going to offer useless options: the computer needs to face East, reinstall Windows and buy a new router. Sitting a chocolate ashtray on top of both would help too.
