1 Monitor, 2 Inputs :(
26 Feb 2007
Leafy Cheshire
hey dudes
Soooooo. My monitor (Dell U2311H) has 1 DVI in, and one VGA in. I was hoping to use it for both my PC and my PS3. My PS3 uses HDMI out. What's the best way of making it work for both? Just getting a HDMI/DVI convertor and swapping them over when i want to use the other?
You could connect the PS3 with a HDMI to a DVI adapter, and then connect the PC with VGA. There's not really any difference between DVI and VGA if you have a good monitor.
I assume he meant HDMI-DVI, then the PC via VGA.
Thanks guys. Will probably just swap, since i cant use both at the same time.
