Hi,
Thinking of upgrading my PC setup to an AMD 5600x and a GIGABYTE B550I - the motherboard has simply a line in, line out and a mic for its audio ports.
The PC speakers I am using are quite old, cambridge soundworks 5.1 jobby, only using them as 2.1 but I have 3 separate 3.5mm jack connections from the sub/amp for; front, centre and sub.
What would be the best way to connect these 3 cables in to this motherboard?
Thanks!
Thanks!
