1 of my folding VM's using 20% CPU usage
Pretty meaningless without knowing what WU it was processing. Your not saying what you consider correct behaviour doesn't help much either.
I expect the 2 threaded application to max out the 2 cores they are working on, so should be at 25%?
I think it is working on P5101 (R0, C6, G111).
5101 is a dog-slow WU so it may not max out its cores. I don't know if you've looked at Task Manager - you'll probably find that the VMs are actually spread out across all eight 'cores' rather than hogging two each.
Looks like it was just the work unit then. Finished that one and it changed to P2677 and my total PPD is at 4400. Probably had 2 of the same type in a row or something.
Cheers for the help.
