- 15 Jan 2004
- Hall
Yep, only one space. Ever.Gilly said:One space for , and one space for .
(2 sandwiches)
(2 sandwiches)
dboundy said:I was taught 2 spaces as standard at college on an ICT course so thats the way I do it.
I also think it's one sandwich if you cut it in half but we won't go into that again![]()
Rich_L said:http://en.wikipedia.org/wiki/Full_stop
Just when you thought Wikipedia couldn't possibly have every bit of information....
The fact that 2 spaces after a stop is 'French spacing' is enough to convince me that 1 space for both commas and stops is in fact the correct method.
dmpoole said:If you cut a space in half is it still one space or two spaces?
The capital letter after the full stop is a bit of a giveaway though, isn't it?Sirrel Squirrel said:... it makes is easier to tell a comma and full stop apart if you're reading quickly.
Meaning that those of us who can and do use the language properly are clowns?Army ofHarmony said:Treefrog, i'm not one of those clowns that type everything in perfect English and correct people's typos etc. I should have expected a reponse like that from a forum like this.
Disagree. Not using it shows a lack of consideration for those people to whom your comment was addressed. And then, when people cba to translate it into something readable, your point never gets noticed.Army ofHarmony said:Using proper English online generally looks rude too.
Two spacesdmpoole said:If you cut a space in half is it still one space or two spaces?
Space isn't defined by size or quantity
If it takes one man 5 days to dig a hole how long would it take 5 men to dig half a hole?Sirrel Squirrel said:its a half space
Dude, if they need extra help in their reading it can't be helpedTreefrog said:The capital letter after the full stop is a bit of a giveaway though, isn't it?![]()
SpecSavers?Sirrel Squirrel said:it makes is easier to tell a comma and full stop apart if you're reading quickly.
half a day?Gilly said:If it takes one man 5 days to dig a hole how long would it take 5 men to dig half a hole?
No such thing as half a holePhnom_Penh said:half a day?
Unless the second hole's half the size of the first hole, therefore should be half as difficult to dig... (Gilly could you have derailled this thread any more?!Gilly said:No such thing as half a hole![]()
).You could've stopped when I made you look sillyPhnom_Penh said:Unless the second hole's half the size of the first hole, therefore should be half as difficult to dig... (Gilly could you have derailled this thread any more?!).
Heh, consider it done.dmpoole said:This is going to go on forever - kill it with fire now.
Maybe we should type more slowly?Gilly said:Dude, if they need extra help in their reading it can't be helped
You shouldn't mock the afflicted![]()
Feek said:The correct answer is simple.
Two spaces after a full stop, one after a comma. I think the forum software doesn't like multiple spaces though and incorrectly truncates two spaces to be just one.
Which is wrong.
K.
