Hi Guys, hope you are all doing well!
I need some advice on a pretty crazy build. I'm building a system for someone who needs it to be able to run 12 independent displays simultaneously. This should be possible running a mobo with 2 x16 slots (Gigabyte Z370M D3H?), with crossfire support and 2 x Radeon™ RX VEGA 56 GAMING OC GPU's which have 6 outputs each + a 1600w PSU. Do you guys think this will be ok? It's definitely worth noting that this system will not be running games or video. It's just to display browsers/office applications across the screens so it shouldn't push the cards hard at all further than running all outputs at the same time.
They have also asked if 18 displays would be possible!!? I think it might be! Upgrade the mobo to something that supports 3 way SLI (Asus Z370 ROG MAXIMUS X?) and simply add another card. Obviously this would then require a 2k PSU and lots of cooling... but do you guys see any potential issues with a rig like this??
Thanks in advance for your advice
