1 pc switching between 2 monitors
28 Dec 2003
staffs, uk
um does any one know if there is a utility (equipment) that can be used to swith a computer from one monitor to another? reason is i have a dual screen setup, but i wanna switch my primary to an hd lcd tv (pc capable) some times when watching movies or playing games.
*subscribes to this thread* I'd like to know the answer to this as well.
I have an Iiyama Pro 450 monitor and want to know if I get something bigger for TV/Movies I can use it for what I may buy it for..
if you want a hardware solution you can get a 2 way dvi hdtv splitter and amplifier which you plug one dvi cable into and it splits it into 2, one for you monitor and one for you hdtv.
they are pretty costly and your screen and hdtv would have to use the same res.
so i would advise using the software equivilent (if you graphics card has 2 outputs) download ultramon and use a dual monitor setup,
in ultramon you can setup display profiles, which are interchangable with 2 clicks of your mouse. e.g.
profile 1 = 1680x1050 res on monitor 1, monitor 2 off
profile 2 = 1366x768 res on moniror 2, monitor 1 off
hope this helps,
StevenG
i already have a dual monitor setup. i just want to link to tv for films and maybe games. its easier to be able to switch cuz i use both pc monitors when doing uni work for my course. hence the need for a splitter
