depends on what size rad you already have, but anything over a triple rad on just the CPU won't make any difference. Also with more rads you will need a very high flow pump (D5 Vario).
More cooling isn't always the key to a high OC sometimes further cooling will make no difference. Push/pull on your Rad, active cooling across your chipset and low ambient room temperatures will all help your OC, but not massively so.
