10 1/2” iPad Pro case needed
23 Jan 2005
So after 2 years my cheap case has fallen apart anyone recommend a replacement, it’s only used in the house so nothing expensive?
Thanks
I used these, found the plastic back would break easily though.
me too - they’re not made out of the best materials. I’ve had a few cases on mine inc Spigen and Apple and found the Khomo ones the best - they’re an OEM fit with good quality materials. Mine was eleven quid from amazon. Bargain.
