So this is weird...
I have been running my new OC settings on my i5 for a few weeks. They aren't 100% stable, but temp wise in prime 95 everything is south of 75 core temp.
The chip on idle was sitting at 37*c and during normal activity rises to 42*c.
Now it is sitting at 50, rising to 60 in normal light work.
Cooling wise, I have a good provision:
Titan Fenrir, polished the base, ShinEtsu G751 paste
18cm fan on the side.
12cm intake fan where the extra drive bays are - took them out, 12 cm exhaust fan, with the perforated metal cut away. The air flow is great, the fans are 78CFM.
I just can't explain this! It seemed to happen after it had a wee crash, actually the first one I had seen yet, it was a memory dump one - blue screen.
I have been through my previous settings, loaded an older OC profile and it too is running much hotter than expected! Have I wrecked my chip?
I was/am running this at 4.3GHz, and I had the VCore pretty lean to keep the heat down.
I would really appreciate some help!
Mike
Mike
