Hi guys running dualcore Opty 175 with Scythe Ninja 1800RPM fan with 42*C core 0 and 32*C core 1 (coretemp) so upto 10*C difference
load temps are 55-58*C and upto 3*C difference in cores@load
1.35vcore
i have reseated hsf with AS5
i have seen a pic of IHS off dualcore and both cores are stuck together so contact with IHS should be the same.
any advise, should i be worried
edit: check pic, shots taken diffent times so temps change. some explain why there is 3 cpu temp and is everest confused?
pc2006 temps reading look odd
1.35vcore
