Hey guys,
I am looking at the possibilities of upgrading our network in work to 10 gigabit to allow our editors to work faster with footage. I have a full Ubiquiti network setup at home and I wanted to use as much of this gear as possible in this new project, however, the lack of a 10 Gig RJ45 switch has me stumped and im hoping you guys can tell me if this setup will work.
I would like to install x2 Unifi 24 Port POE Gigabit switches, a new Unifi Gateway and connect these and our 10 Gig Synology DS1819+ together with a Unifi 10 Gigabit Switch. My thought behind this is to use the SFP ports to connect the switches, gateway and the Synology together, while using the x4 RJ45 ports to connect to local workstation via Cat6. I will also have a Cloud key (Gen 2) and a few wifi access points dotted about.
Our editors won't be editing directly from the Synology, as they only use Proxy media at this stage. They do however connect and render out the final project using the files located on the server. I also want to use a 10 gig connection for ingesting footage as our camera operators come back from filming, this should improve our network speed overall.
Our current network is made up of old networking gear, including Draytek, HP, Netgear and TP-Link. I want to use this time and budget to completely upgrade our entire network, including wifi, while allowing the possibility of future expansion.
It would be great to hear your thoughts on this and any recommendations are welcome.
