Hi Guys
For a limited period, Corsair are running a promotion where we are able to offer £10 off the price of the fantastic Corsair Vengeance 1500 Headset.
This is an opportunity not to be missed for anyone in the market for a high end surround sound gaming set.
Winning multiple awards from the likes of Kitguru and Hardware Heaven, the 1500 is a brilliant combination of high end features and value for money.
Corsair Vengeance 1500 Dolby 7.1 Professional USB Gaming Headset @ £64.99 inc VAT
If you have onboard sound, the Vengeance 1500 provides easy one-cable USB connection and Dolby Headphone technology that lets you enjoy multi-channel games the way they were meant to be played. Dolby Headphone is compatible with any game with 3D audio, and helps reduce “headphone fatigue” while delivering the accurate 360-degree audio imaging you need if you’re playing to win.
The massive 50mm drivers greatly reduce the overloading and distortion that can occur with gaming headsets that use 40mm drivers. You get more accurate sound reproduction (particularly for the all-important low-frequency effects). You hear more audio, more cleanly, and you get a competitive advantage.
The extra-wide, extra deep earcups don’t just help things sound great — they feel better, too. Customize your comfort with your choice of the included microfiber or synthetic leather covers. Both use memory foam earpads for a comfortable, reliable fit that conforms to the shape of your head without binding or pinching.
The circumaural, closed-back design blocks distracting sounds and keeps your head in the game, and the extra-large inline volume and microphone control is easy to grab and use when the action heats up — you don't need to take your eyes off the screen.
Whether you’re barking instructions to your teammates or chatting with old friends, you deserve to be heard. The unidirectional, noise-cancelling microphone is tuned to capture your voice loudly and clearly, while screening out distracting background noises. And, it flips out of sight when you’re not using it.
Corsair audio: a sound philosophy
You need more than just dramatic audio. You need the comfort that allows you to play or talk for hours without thinking about what’s on your head. You need fidelity that gives you a listening experience that’s not just immersive — it must also be true to the source material. And, of course, you need the detailed positioning and situational awareness that lets you play your best.
- Intense, Immersive Gaming
- Dominate with Dolby 7.1 Sound
- Superior Comfort
- 3m Cable
- Large 50mm Audio drivers
- In Line volume control
- High-sensitivity noise-cancelling microphone with flexible boom
- USB connections
- Two Year Warranty
Was £74.99 Inc. VAT
Only £64.99 inc VAT.
ORDER NOW
- Superior Comfort
- 3m Cable
- USB connections
- Two Year Warranty
Was £74.99 Inc. VAT
ORDER NOW
