£100 for upgrade
22 May 2013
amd athlon 64 x2 2.4ghz
hd 4850
n68C-gs fx motherboard
Corsair CX430 builder series power supply
I want to upgrade my cpu and case - currently I have a case with 0 fans and all cramped up, I have to use a desk fan and keep the case open in order to keep it cool.
I have exactly £100 and can't spend anymore unfortunately, so it must include shipping also.
I'm not very tech savvey but if someone could recommend products that will fit what I currently have then it'd be really good!
thank you!
edit: use computer for playing dota 2
I was surprised as well, shame op does not some extra cash for the 6300.
Yeah it's a tight budget. I'd shoot for the 6300 over the 4100 too.
He might actually just be better off looking for a 2nd hand Phenom II 955/965BE (Some of the 550/555s unlock to a tri or quad if his mobo has the unlock option but it would need a better cooler than stock to tame the extra heat). That would give him more cash for a better case perhaps?
4300 vs 965
