Hello, I'm looking for some guidance with my first and possibly only build, I'd be really grateful for some opinions.
My budget is around £1000, up to £1200-£1300. However, if there are worthwhile/more valuable upgrades then I'd be willing to consider it. The PC will be used for gaming, working (making websites + digital media), video editing, music production - and over its lifetime any new hobbies that I pick up
The reason I decided to go for i7 is because I believe I will be making use of the multithreading.
PC
CPU - Intel i7-6700k 4.0GHz (Skylake)
CPU cooler - CoolerMaster Hyper 212 Evo
Motherboard - Asus Z170 Pro Gaming Intel
Memory - Kingston Fury Black 16GB (2x8GB) DDR4
Storage - Samsung 850 EVO 250GB SSD
Western Digital 1TB 7200rpm
Graphics Card - Sapphire Radeon RX 480 Nitro+ 4096MB GDDR5 PCI-Express RGB
Case - BitFenix Nova Midi
Power Supply - Corsair VS 550W '80 Plus'
OS - Microsoft Windows 10
Things to consider/my questions
Monitor
The budget is excluding a monitor, but again I'm pretty clueless. These are some that I have seen which are around the size/price range. I read that IPS is better than TN? I think these are TN but how much does it matter?
BenQ GL2450HM 24 inch 2ms
Asus VS248HR 24 inch 1ms
Acer G246HL 24 inch 1ms
Please assume I know very little about this and if I have missed anything off the build/out of the message then I don't know about it
Thank you so much for your time in reading this message and any help you can give me
x
The reason I decided to go for i7 is because I believe I will be making use of the multithreading. PC
- Can you see any problems with compatibility?
(Now or in the future - I'd like the option to swap out parts that need upgrading, will this likely be compatible?) - Does this build have longevity?
(are they quality parts, will things get updated (substantially) very quickly?) - Should I consider a full tower case or will midi be ok?
(For now and in the future - enough space?) - Are there any parts you would consider swapping out?
(better value, better quality?) - What's missing that I would need to get up and running?
a) I need to be able to use both ethernet and wifi, do I need separate adapters for these?
b) I'm absolutely clueless with any cables or adapters I would need, or whether they are included in the parts I'm getting.
Monitor
x
