100BaseT switch and Broadband
25 Jun 2005
Hello,
I'm getting myself confused and the more I read the more puzzled I get! :confused:
I'm looking at getting a decent switch, I've been offered a 10/100BaseT switch.
I currently have Virgin's 20Mb cable coming in, the switch will have 2 machines connected to it and a WAP at some point.
Is the 100Mbps of the switch going to limit the incoming 20MB from Virgin.
My head says no but I'd like some clarification, the Virgin is apparently be upgraded they say to faster speeds in the next 6 month.
I knew it was internal traffic only but only going to 2 comuters I didn't want a bottleneck.
Also for knowledge more than anything can you exlpain the 100>20 statement, i was under the impression one is bits and other bytes.
You're right, it is - except that Virgin is 20Mbps not 20MB (which is ~ 160Mbps which isn't offered in the UK).
From a 20Mbit connection you should expect to see around 2400KB/sec download speeds which equates to around 2.35MB/sec.
There are 8 bits to a byte so theoretically 8Mbit is equivalent to 1MB. In theory 20Mbit would be 2.5MB but the reality with overheads is 2.35MB. That's what I got when I had 20Mbit Virgin anyway.
In this context it’s all bits.
A 10/100 switch will handle any Virgin connection up to their 100Mb offering.
For their 120Mb connection you'd need a Gigabit switch to completely avoid the possibility of a bottleneck.
As Gigabit switches start at about £16 there’s not much point buying 10/100 switches anymore.
