Hello, I've found expert forums really helpful in the past, and often full of the kind of people who like puzzles- hopefully.
In brief- 3 years ago I had Gigaclear fibre optic installed FTTP, and it has never worked well, literally buffering on std quality TV, wifi phone calls drop, particularly if I'm trying to email attachments at the same time. After 3 years of frustration, and literally hours of tech supoprt calls with Gigaclear, today I finally got some validation;
The tech support team told me they'd discovered that in the last 5 years I've NEVER used more than 5Mbps bandwidth, and "that is unusally low". ( I have 3x Alexas, 1x Ring doorbell, a laptop, mobile and TV).
I fully believe I've been running on max 5Mbps for the last 3 years. But Gigaclear say they haven't limited it. Also 90% of the time speed tests show 30-100Mbps (100Mbps is what I pay for). 10% of the time tests come back sub 5Mbps, Occasionally sub 1Mbps.... but usually when download speeds are low, upload speeds higher. I have a screenshot from earlier this week of 3.15 download and 70.25 upload. (It's 12.15am and I've just done an Ookla test, download 27.78Mbps, Upload 43.20Mbps).
What has been tried;
I've been through all the standard tech support stuff many times, including being talked through checks of settings by several different members of staff and they've never found anything untoward.
Gigaclear thought the router was faulty, but I've tried 4 different ones now. I've also swapped power cables and data cables.
Gigaclear said the router range wasn't enough for my house- My house is small but I set up 3 interlinked Linksys Nodes so nothing I use is more than 4metres from a Node, but the problem persisted.
Yes I have the same bandwidth issues on my tv, phone and laptop, ( also on my old desktop).
Gigaclear told me to move the master node as it was within 4 metres of a fridge and a mirror- I ignored them
So ANY ideas as to what could be capping my bandwidth at 5Mbps when Gigaclear say it isn't them, and when I can still get up to 100Mbps on a speed test?
Is it a red herring that upload speeds can be 100Mbps when download speeds are sub 5Mbps?
I live in a village with poor mobile signal and my only other internet option is the ancient BT copper wire, which the previous owner warned me off because the box it terminates in floods when it rains.
Any ideas would be most welcome. Thanks
Susie
Susie
