10400f (b560) or 5600x (b550) streaming with nvenc
22 Nov 2010
Kettering
Hi guys,
Going to be buying a custom pre built PC and deciding on a CPU for it, I game as well as stream and record at the same time.
So just wondering if I would see a difference from using a 10400f or a 5600x while streaming but using the nvenc GPU encoder.
Can anyone shed some light? Thanks
Quite a difference between the 3080 and 3070 Ti, I would go with the 5600X setup in that case. For streaming/recording using nvenc anyway 6 cores/12 threads will be enough.
How big is the price difference between the two? If it's quite big then settling the for 11400F should be fine but the 5600X is the better performer.
Well I've found a deal, 5600x b550 MSI gaming edge and 16gb crucial 3200 for £400, so think I'll do that and hold on for a FE 3070ti, full build we be about £1300
Ive just put together a 5600x, B550, 16gb 3600 and 3070ti system, its a good balance I think, performance is great although not tried gaming + streaming yet. I do recall that Intel had issues with stutter when streaming and gaming, probably been resolved now but it was definitely a thing.
I'm literally about to order the same spec.
Found a good CPU mobo deal, so going to do that and get a 70ti FE card
So I can go to a 5800x or 11700f, but means moving GPU from 3080 to a 3070ti.
Still worth doing?
NO! but if going 3080 get the 5600X it is a significantly faster gaming CPU and the 3080 will need it, but either way the 3080 is always better than the 3070TI.
Edit: unless you get that good deal on the 3070TI, the 5600X is still worth the difference over the 10400F
I'm going to go for the 5600x system anyway I think, as found a CPU/mobo deal on it, and going to hold out for a 3070ti FE, should be around the £1200-1250 mark all in
If it helps, my full build below, was soo easy to build, easy to get really neat and tidy and everything just worked as it should ( I did Qflash the bios to the latest version before building) very pleased.
Ryzen 5600x
Artic Freezer pro II
Gigabyte B550M AORUS PRO-P
Crucial Ballistix BL2K8G36C16U4B 3600 MHz
RTX3070ti FE
Lian Li Lancool 205M
Corsair RM Series RM750 750W PSU
WD_BLACK WD Blue SN550 2TB SN750 500GB
WD Blue SN550 2TB
120MM Noctua fans
3080 FE is absolutely worth the extra money over a 3070TI (talking MSRP prices here and this is obviously assuming you can actually get a 3080, they are the hardest Nvidia FE cards to get)
