- 11 Mar 2008
Currently running an office PC with a 750ti with 3 x 1080p monitors, however I'm going to upgrade the PC (including a 1050ti) and I'm thinking about going to 3 x 1440p monitors.
Does anyone know if a 1050ti will be able to handle displaying 3 x 1440p? Desktop usage only, not for gaming.
Going by the specs, it looks like it should, DP1.4, HDMI 2.0 and DL-DVI, but in practice does it actually work?
I suppose the ports may be a factor in terms of the connections, if I went for the Dell U2515H then they would not accept DL-DVI anyway, can you convert DVI to HDMI at that resolution? I think any adapters I've seen before are limited to 1920x1200.
