- 27 Aug 2006
Hi,
Ive tried to overclock a 1055T that i brought today. Default the cpu runs great, 24degrees with a Zalman performa, with an additional fan in a push/pull config in an antec 900 case. Running OCZ reapers 12800mhz C6.
Disabled C1E, Virtualization, C&Q
IGX disabled
CPU Clock Ratio: 14x
CPU NB Freq: 8x
Core Perf Boost: Disabled
CPU Host clock control: Manual
CPU Freq: 250 (3.5ghz)
PCI clock: 100
pcie spread spectrum: disabled
HT link width: auto
ht link frequency: 8x
memory clock: x4
Dram (7-7-7-30)
DRAM Volt: 1.62
CPU Volt control +0.175v (1.45v)
Doesnt boot, it comes up with 'system has experienced boot failures because of overclocking.'
What am i doing wrong? I thought the 1055T could hit 3.5ghz easily and 4ghz was a struggle?
The computer boots at 13.5x300 (3.3ghz) and running Prime95 seems fine, temperatures are around 27, mostly 27 but peak at 29 max
managed to get to 3.6ghz, trying for 4ghz
http://i38.tinypic.com/vqqko2.png
managed to get to 3.9ghz, but the temperature is maxing at 3.8degrees, both Hardware monitor and amd overdrive show the same thing. TMPIN1 is max 45degrees, TMPIN2 is 52 degrees isnt this a little low? Is something broke? I want to overclock further but i dont want to overheat the cpu.
IGX disabled
CPU NB Freq: 8x
PCI clock: 100
HT link width: auto
memory clock: x4
Dram (7-7-7-30)
DRAM Volt: 1.62
. . . you can open multiple copies of CPU-z from the same shortcut . . .
