1080GTX + 240 top/rear radiator.
7 Jul 2016
Hello chaps,
I'm planning on upgrading my tired gen 1 C step i7 to one of these bundles;
https://www.overclockers.co.uk/8pac...rclocked-bundle-150-pounds-off-bu-00l-8p.html
Which requires a 240mm radiator mounting point in the top/rear, so seems I'm getting a new case too.
It also has to house a 325mm long 1080 GTX.
So the question is, which cases fit the bill?
Nothing garish, please and under £100.
Cheers, dudes.
You don't need to mount radiator top/rear. Front is still ok, not much difference and with smaller cases like NZXT S340 front might be the only option
Other worth noting cases Phanteks P400, Phanteks Enthoo Pro, Fractal design Define C. All depends on which style you like best. They perform similar. Some of them have options with tempered glass or solid panel, some of them have plastic window (fractal).
Cheers for the reply :)
That's handy to know about the mounting location, I'm just going on the text from the bundle as I've not run an AIO before. I figured it might be some weird routing orientation or something. But that helps a lot if I can just look for a suitable dimension instead.
Thanks.
Yeah I saw that, weird...anyway it's worth to watch YT video on pc build in a specific case (plenty of them) and usually there are some with AIO
