I have a 120hz tn benq already.. happy with it.. but want a second lcd 24"
what to get though ...144hz tn or 60hz ips (if only for the better color/viewing angle)
price.. low as possible for the best lcd (not sure oc prices are all that good from what i'm seeing but any recommendations on lcd's models to look out for ) .. won't be gaming on the 2nd lcd so don't care much about the refresh rate.. but I do care about the refresh rate if its going to a problem with any applications on the desktop.
I've heard of people having some weird lag issues when both lcd's are not running at the same refresh rate?
can a 144hz lcd run at a lower 120hz? I assume yes?
also the gfx card this will be used with is gtx660 will it be enough to push 120hz + 144hz should I go that option? obviously if I get the 144hz lcd that will be the main
but i'm kinda fine with the 120hz tbh just having difficulty deciding on what the 2nd lcd should be that is under £200 pref under £150 best near £100
