1080p gaming build ~£700
19 Oct 2012
cheaper board (just as good, but without the branding), faster ram (b360 only supports until 2666mhz, though), better gpu (6gb version), bigger ssd, better psu, swapped case for MATX build
My basket at Overclockers UK:
Total: £759.44 (includes shipping: £12.60)​
ryzen option. for out-and-out gaming, the intel option would be better. if running mixed loads together, the ryzen option is better.
of course for both builds, can cut down to fit a budget, but imo, these parts are the best bang-for-buck components, so better to spend that little bit more instead
Total: £786.44 (includes shipping: £12.60)​
stuck with the i5, but went with an atx board that offers faster ram, chose a 1050ti to enable 16gb ram, chose a better power supply and went with a 1tb sshd for small ssd performance but with huge storage, but if you happy with a single 240gb ssd then get the teamgroup for few quid less. case, kb/mouse subject to preference.
Total: £712.02 (includes shipping: £12.60)​
Tamz is solid, would stick 2400 kit though, makes life easier then playing with speed and timings
Also , cryorig intel cooler £15
https://www.overclockers.co.uk/cryorig-m9i-single-tower-heatsink-for-intel-hs-00a-cy.html
Heck you could even stick an i3 8100 ... It's 4 core 4 threads. Same as i5 of older gens people hAve been using for last 9 years :)
Still fly for gaming as most games have recommend specs for older 2/3rd gen i5 .
Lets you have the gtx 1060 5GB in budget
